Home Door Alarm
Discussion in 'The Projects Forum' started by wardyyboyy, Nov 20, 2008.
  1. wardyyboyy
    Nov 20, 2008
  2. Bernard
    Aug 7, 2008
    4,237
    414
    Use a NO reed sw.[no magnet close ], mount on door frame. Mount magnet on door close to switch. Check for sw. continuity with door closed.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I don't know what you're using to create your schematic, but you'd be better off using something like Cadsoft's Eagle Layout Editor.
    http://www.cadsoftusa.com/
    It's quirky to learn in the beginning, but you can go from making a schematic to generating a PCB. The free version is limited to 2 layers, and 3"x4" boards - but you can still do a lot with it.
    There are a number of Microchip uP's in the libraries already.
    You might consider using a PIC16F886 or PIC16F887; they have a reasonable amount of memory, lots of I/O pins, you don't have to fiddle with an external oscillator or crystal, and they're inexpensive.
