Home brew PCB's
Discussion in 'General Electronics Chat' started by capnray, Dec 9, 2011.
  1. capnray
    Jul 3, 2010
    59
    I use positive sensitized MG Chemicals boards and developer through Mouser. It is slick and my etchant is also home brew and fast.
    I had a long post that went to cyber hell, so I'll attempt only a reply to questions. Pictures are attached.
    I have beaten several barriers in my quest for easy to make PCB's and have succeeded!!!
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Did you buy photo sensitive boards, youor you applied a photosensitive solution to the board? (Sounds like coated board, but that big chunk was sitting in light, so I had to ask)
    The results are nice with crisp edges on the lines. I do toner transfer if I end up making a board.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I still have a dozen aresol cans of MG photoresist that I bought 20 years ago. Still works great.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It can be a challenge sometimes. I've found when learning the method you want to use there is always a lot of trial and error. After you perfect your personal technique it looks easy to everyone else.
    Project: How to make PCBs
    If you add a bit more detail I think it would make a good addition to the completed projects. It is one of the things folks new to the hobby are always interested in, and as with many things there is more than one way to do it well.
    I'm still ironing a few bugs out of my personal process.
  5. Meixner
    Member
    Sep 26, 2011
    116
    21
    What PC software are you using to do your design ?
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Currently I am using PCB Express, but it doesn't matter. Right now I have to use GIMP, because it is the only software that will print 600DPI to my printer.
    I also take the time to touch up the PCB print to my personal specs using MS Paint, mostly in redefining my pads. Compared to layout it doesn't take long.
    The major strength of your method is the alignment of double sided designs. It is something toner transfer doesn't do very well.
  7. spinnaker
    Oct 29, 2009
    5,065
    1,174
    Bill,
    PCB Express should print 600 DPI too. It just lacks property change features on print. One the the few things I hate about PCB Express.
    Just use your property settings from the OS printer control. It should work.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    It works, but I do not like Express's pads. I believe I've mentioned I redefine them?
  9. spinnaker
    Oct 29, 2009
    5,065
    1,174
    Ah I thought it was to get 600 DPI.
    What do you do to the pads? Can you post a comparison?
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I threw in some pictures of the finished product too. I missed a couple of pads, can you spot them?
