I need to create a circuit that is a holiday decoration that fullfils two basic components:
1. A solid background consisting of LEDs that is "on" whenever your Power On/Off switch is on and "off" otherwise.
2. A flashing foreground consisting of LEDs that are "on" for a period.
Optional: Create a fade in/fade out feature to the flashing foreground.
I have few questions about this:
1. I initianlly just put an LED via pin 8 to give it the solid background. Is there any other way I can set up the background using an op amp?
2. I am going to put LEDs in parallel (all same LEDs) so that they have the same brightness. Is this a bad practice if so is there any other way to set up the circuit so that I achieve the same brightness for the LEDs?
3. Will a circuit like mine need a capacitor in pin 5? If so, why?
4. Any hints on how to do the fade in fade out feature?
