Holding a Signal
Discussion in 'The Projects Forum' started by skiziks, Oct 17, 2007.
  1. skiziks
    Oct 17, 2007
    Hi everybody,
    I'm currently working on a project where I need a signal to be held for a few seconds. In my circuit I've got a series of LED lights which go on in a series depending on the change in voltage caused by a varibale resistor (strain guage), so more voltage drop, more LEDs go on. I was told that I need to use Dual D-type flip-flops (two of them) to hold the signal, but I don't know how to implement them.
    Advice would be welcome and appreciated.
    Thanks alot.
    Skiziks
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The signal out of a strain gauge is analog in nature. Using a sample-and-hold amp seems to be more the thing.
    With no schematic or circuit description, it is very hard to give a good answer. Doeas the strain gauge bridge get amplified and then get digitized? That is the only way a flip-flop might be of use.
