holding a DC motor at stall current
Discussion in 'The Projects Forum' started by kutalinelucas, Dec 12, 2011.
  1. kutalinelucas
    Thread Starter Active Member
    Nov 20, 2007
    98
    hey guys...
    I'm just wondering how damaging it is to hold a motor at its stall current for a period of 10 to 20 seconds...
    Any ideas would be brilliant
    cheers
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    at rated voltage without current limiting, very.
  3. kutalinelucas
    Nov 20, 2007
    98
    ah...ok I do have a (firmware) way to get around this, but just out of intrest, my motors have a stall current of 500mA; and they're being driven by L293D H-bridge drivers with a current limiter of 600mA per channel, would this still do some damage?
  4. Markd77
    Sep 7, 2009
    2,803
    594
    Maybe not to the circuit, but the windings in the motor will overheat very quickly and die.
  5. kutalinelucas
    Nov 20, 2007
    98
    lovely...thanks for the info
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    You could add a PTC fuse rated for 450mA.
    I see that the stall current IS 500mA
    What is the running current?
    When a brushed motor stalls, the current typically shoots up to what is allowed by the DC resistance of the motor windings. Add a fuse to blow when that current is met or exceeded before the windings melt.
  7. kutalinelucas
    Nov 20, 2007
    98
    the running, no load current is ~300mA (due to a 76:1 spur head on the output).
    Putting in a fuse wouldn't really solve the problem as my system knows when the motor has stalled through feedback from a H.E quadrature encoder so I can protect the coils...but ideally I'd like to maintain some holding torque when the load on the rotor stalls the motor...could you think of a way to do this?
    For instance, could I increase the mark-space ratio in the applied pwm signal so a lower average voltage is applied across its terminals?
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    If you have a 76:1 reduction, how much torque is needed on the output to backspin the motor? Maybe you could somehow short the motor leads and let the generator effect provide holding power.
    (ED) If you have encoder feedback, can't you use it to generate forward/reverse commands to hold a position?
  9. kutalinelucas
    Nov 20, 2007
    98
    it does to a certain extent...the (4) DC motors are being used to actuate the upper/middle knuckles of a robot hand, where translation of the joints is achieved by using the output of the DC motors to twist two parallel strings which creates a tortive effect, reducing the overall length of the tendon. The beauty of this approach is high output torque, but also inherit compliancy, so the hand can grasp most objects without a prior model of its attributes. I have sensors placed over the hand which informs the control system of any contact, but heavier objects seem to require some amount of grasping torque...so really I'd like to maintain some power accross the motor without burning the coils, ideally anyway. Its not crucial to be honest but it would be nice to manipulate heavier objects
  10. kutalinelucas
    Nov 20, 2007
    98
    Fantastic, can't believe i didn't see that...thanks so much for the help
  11. BillB3857
    Feb 28, 2009
    2,402
    348
    That's the difference between open and closed loop servo systems.
