hnc question
Discussion in 'Homework Help' started by redshaw, Jul 16, 2008.
  1. redshaw
    Jul 15, 2008
    12
    could anyone help
    a single phase motor takes 50 A at a power factor of 0.6 lagging from a 240V, 50 Hz supply. Determin a.) the current taken by the capacitor in parrallel with the motor to correct the power factor to unity, and b.) the value of the supply current after power factor correction.
    i worked out the Ic by
    pf=cosO
    0=cos -1 (0.6)
    0=53.13
    true power=Vcoc0
    =240 cos 53.13
    144W
    Q=true power * tan 0
    Q=144 * tan 53.13
    Q=191.99 VA
    Ic=Q/V
    Ic=191.99/240
    Ic=0.799A
    but am struggling with the value of the supply current question b
    i have calculated Xc as 300.38 ohms and C as 0.106uF but dont know where to go from here
    can anyone help
    cheers
  2. redshaw
    Jul 15, 2008
    12
    is the answer to b just simply
    supply corrected to power factor of 0.6 = 144W/(240V*0.6)
    =1A ?????????
  3. Ratch
    Mar 20, 2007
    1,068
    redshaw,
    I'll try.
    The apparent power is 50*240 = 12000 volt-amps
    The average power is 12000*.6 = 7200 watts
    The reactive capacitor power is sqrt(12000^2-7200^2) = 9600 vars
    The reactance of the capacitor is (240^2)/9600 = 6 ohms
    The reactive current is sqrt(9600/6) = 40 amps
    The current after correction is 7200/240 = 30 amps
    So correcting the power factor reduced the current load of the power supply by 20 amps. Ask if you have any questions.
    Ratch
  4. redshaw
    Jul 15, 2008
    12
    thank you for your assistance
