HNC electronic science......please help
Discussion in 'Homework Help' started by hncelectronics123, May 23, 2008.
  1. hncelectronics123
    May 23, 2008
    10
    Hello, I'm in my second year HNC and is my only outstanding assignment which i need help with. The following questions with the working out are required.
    The circuit is an RLC parallel and the following are the known given value's;
    Votage suply = 30vac at 50Hz
    capacitor = 150uF
    Resistor = 18 ohms
    inductor = 100mH
    Question 1a). Determine all currents
    b) use the currents in (1a) to draw a scaled phasor diagram
    c) Determine the following for the circuit
    Active power
    Apparent power
    Reactive power
    d) Use the results in (c) to draw a power triangle
    e) determine the power factor
    If any one could please help me with completing this assignmen then it would be much appreciated.
    Thanks in advance people.......
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
