HITECH C compiler error
Discussion in 'Programmer's Corner' started by Strathspey, Mar 15, 2011.
  1. Strathspey
    Mar 15, 2011
    Could somebody please explain the following compiler error:
    160. constant operand to || or &&
    which points to the following line of code:
    LCD_DATA = cmd && 1; /* set RS bit, 1 == data, 0 == command */
    Thanks in advance
    Pat
  2. someonesdad
    Jul 7, 2009
    1,585
    141
    It probably should be a warning, not an error (compiler writer's choice). You need to understand the difference between the && and & binary operators. You probably meant &, not &&.
  3. nigelwright7557
    May 10, 2008
    488
    71
    & is a bitwise AND.
    && is a logical AND.
