Hitachi 42PMA400E power supply
Discussion in 'General Electronics Chat' started by rastaman46, Aug 24, 2014.
  1. rastaman46
    Nov 17, 2011
    69
    Hi all
    I got hitachi tv that wont turn on when i press power buton all it does is makes relay clicking noise but wont turn on.
    I diasembled tv and on power unit found 2 diods burned
    Can any one tell me is diod can cause it please?
  2. rastaman46
    Nov 17, 2011
    69
    I have removed diods from board mesuared with multimeter and i have 470v on
    Negative to negative and positive to positive
    And reads 0 other way round is that ok 470v?
  3. ISB123
    May 21, 2014
    1,240
    531
    Replace them with similar ones,and check the other side of PCB to see if traces are damaged.
    rastaman46 likes this.
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    It looks like the diodes have been very hot, but are not burned (the PCB is discolored).
    Check the large capacitors for bulging or leakage.
    Does the meter have a diode test function?
    This should read OL (or an other value for open lead) in one direction and about 0.5 to 1 (the voltage for the test current) in the other direction.
    Bertus
  5. ISB123
    May 21, 2014
    1,240
    531
    To me it seems that traces are damaged since it looks like the discolored part is following a trace.
  6. rastaman46
    Nov 17, 2011
    69
    Its shows ol in one and 471 in other direction
    Traces are fine
    What can couse this problem where i need to start looking
  7. ISB123
    May 21, 2014
    1,240
    531
    Check the caps like bertus said they generally are cause of problem in PSU.
  8. rastaman46
    Nov 17, 2011
    69
    All caps looks like new
    It have fan on supply when i turn tv on fan spins just for split sec then click noise and off again
  9. ISB123
    May 21, 2014
    1,240
    531
    The click noise is from the relay shutting down the TV.Since you cant get the error code you will probably have to take it to a repair shop or order a new PSU which is like 60€,check the fuse.
    For how long did you have the TV?
  10. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    It looks like the powersupply goes into protection.
    There must be an overload somewhere.
    Bertus
  11. rastaman46
    Nov 17, 2011
    69
    How do i check it or where to start checking?
  12. ISB123
    May 21, 2014
    1,240
    531
  13. rastaman46
    Nov 17, 2011
    69
    Checked to that link
    Got 5v to pin 6
    And pin 1 &10 gnd 6 i got no voltage at all
    What else can i check?
  14. rastaman46
    Nov 17, 2011
    69
    Got tv on some how !!!
    I gonna do some deep investigation to power supply
    Thanks all
  15. ISB123
    May 21, 2014
    1,240
    531
    Tell us what did you do in case someone has the same problem.
  16. rastaman46
    Nov 17, 2011
    69
    Gone true pdf u send me
    All was linking to power supply
    Then i just gently moved all parts just in case of cold solder
    Then pluged cable in boom fan did not gon off
    Looked at the screen boom picture
    Now testing in case it go funny again
    At least i know here power unit cause it
  17. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Discolouration of the PCB is not as uncommon as it should be!
    A DMM set to the diode test range should be used to check each diode out of circuit.
    Its more likely that something on the load side of things is shorted and activating the PSU overcurrent shutdown.
    A relay clicking could be the delay circuit for degauss in a CRT TV - the only thing I can think of a relay for in a LCD TV is possibly inrush surge limiting, either way it probably doesn't indicate much about the fault.
  18. ian field
    Oct 27, 2012
    4,447
    791
    If those readings are from an analogue meter Ohms range, the 471 is pretty much meaningless.
    Most DMMs have a diode check range that gives the forward volt drop of a diode - the reading gives some clue to what type of diode it is.
    For leakage; you need to reverse the test leads and switch to the highest resistance range - normally any leakage indicates a faulty diode, but Shottky barrier diodes show some leakage as normal - recheck the forward voltage, a SB diode should read possibly as low as 0.2V.
