OK, I know this is probably asking way too much but I want to direct an HF signal (say 27MHz initially) into the ground from a portable antenna. A lot of Googling has turned up all the usual antenna types but I was wondering if there was something that could be done to produce something more uni-directional.
The reasons for wanting high directionality is to get as much energy as possible into the ground, reduce noise and interference and as far as possible to ensure the receiver is receiving a signal from the ground rather than via other paths.
So suggestions please? Ideas I've had are an active antenna inside a metal tube, a loop antenna with a dish or plate on the back of it, some kind of loop with parasitic elements. I don't know a great deal about antenna design and don't know where to start with modelling these things, is there free software that would help?
