Highest Frequency
Discussion in 'General Electronics Chat' started by darenw5, Sep 22, 2008.
  1. darenw5
    Thread Starter Active Member
    Feb 2, 2008
    45
    For all tinkerers who like to push the limits...
    What is the highest frequency signal you've managed to generate from circuitry built yourself? Merely applying power to a pre-made oscillator module or a radio doesn't count, and no fair microwaving your lunch and claiming that. From a circuit of discrete components that wouldn't oscillate on their own. Whether for radio purposes or otherwise.
    Is it fairly easy to get into the higher realms of microwaves? Has anyone at a more or less hobbyist/tinkerer level ever gotten up into THz?
    If you have an interesting story about any such attempts., please tell!
    Personally, many years ago i was messing around with some 74LS series TTL chips, and got an inverter with a tiny handmade inductor and using stray capacitance to oscillate at somewhere over 30MHz. Unimpressive by radio tinkering standards, but it was really pushing digital logic for the time.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,384
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I used to build coffee can down coverters, which had a 2.25 GHz VCO that was tuned by triming the PC boards. They were kits, but nothing was preassembled. They used a 1 pound metal coffee can as a resonant cavity with an antenna in it (made from scratch from semirigid 50 ohm coax, the thin high frequency stuff with a solid metal jacket and solid wire core) and down converted a microwave TV station to channel 3.
    Does that count?
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,384
    About 30 years ago I have used 10 Ghz transmitters as a HAM (radio amateur).
    Those where made with waveguides and gunn diodes.
    Greetings,
    Bertus
  5. scubasteve_911
    Dec 27, 2007
    1,202
    One time I made a switching converter from scratch, it ran at a whopping 50KHz!
    Seriously, the highest frequency I used in a design was 915MHz (ISM band requirements), which is nothing compared to what most others have done.
    Steve
  6. darenw5
    Feb 2, 2008
    45
    Interesting...
    Bertus - where did you obtain the Gunn diodes? One of the usual parts suppliers?
  7. scubasteve_911
    Dec 27, 2007
    1,202
  8. darenw5
    Feb 2, 2008
    45
    I will begin drafting my "Dear Santa" letter now...
    A Gunn diode would be a fun toy to tinker with!
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,384
  10. DickCappels
    Aug 21, 2008
    2,755
    665
    432 Mhz using a SAW. I have recently received a couple hundred 6 GHz transistors...
