Higher voltage?
Discussion in 'General Electronics Chat' started by taozeo, Mar 12, 2013.
  1. taozeo
    Nov 11, 2010
    Is it possible to build up a higher usable voltage via a capacitor from a small solar cell?
    What I'm trying to do is build up 1.5-2.0v from a 0.5v solar cell within a capacitor to use after it achieves this higher voltage. Is this possible? Unless I misunderstand, this is how stun guns work, right?
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Very possible. Google joule thief.
    Also look at the following chips:
    LTC3105
    LTC3108
    taozeo likes this.
  3. crutschow
    Mar 14, 2008
    13,473
    3,361
    It's difficult to step up 0.5V since it is so low and below the turn-on threshold voltage of typical transistors. Typically several solar cells are placed in series to get the desired voltage.
    taozeo likes this.
  4. taozeo
    Nov 11, 2010
    Thank you, MrChips! These chips appear to do exactly what I wanted. I wish I would have known about them before I ordered the 1381's IC's based on the "Miller Solar Engine" circuit I found here: http://www.solarbotics.net/library/circuits/se_t1_mse.html I've build this circuit and cannot seem to get the capacitor to charge up beyond the supply voltage of the solar cells... any advice on this? I'm hoping to make this work without having to purchase additional parts ($5 part with $10 shipping!)
  5. praondevou
    Jul 9, 2011
    2,936
    489
    Where does it say that this circuit increases the capacitor voltage above the solar cell voltage? They are both in parallel.
    In general google for "solar cell energy harvester". There are many new developments available. ex:http://www.ti.com/lit/ds/symlink/bq25504.pdf
    Pay attention to the package when buying these chips, they come often only on QFN/DFN packages, difficult to solder without the right equipment.
  6. taozeo
    Nov 11, 2010
    Thanks, Praondevou, I thought that strange as well. Maybe I misunderstood but if you read the second paragraph on this version: http://www.solarbotics.net/library/circuits/se_t1_1381.html it states the 1381 increases the voltage from 0.2v-0.3v to a much larger value in order to run a motor from a small solar cell... so I assumed it would work.
    Thanks for the link, I'll check it out.
