Higher value capacitors in P/S
Discussion in 'General Electronics Chat' started by redrooster01, Jul 24, 2015.
  1. redrooster01
    Jul 15, 2014
    84
    Would it be safe to use 4700uf instead of 3300uf capacitors in a tapedeck power supply? Ive marked the ones I want to change,C336 has a ''star'' above it that just means it has a part number.I live in a fairly remote area and it takes weeks to order anything through the post but I can get the 4700uf caps here OK. Ive spent about an hour looking for a previously answered question on this subject without success.Any help would be appreciated.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,709
    1,301
    If it will fit physically (diameter, height, lead spacing), I don't see any problem. 35 V is a minimum for this application.
    ak
    Roderick Young and redrooster01 like this.
  3. redrooster01
    Jul 15, 2014
    84
    Thats good to hear! Im being careful because the tapedeck is a vintage high end Pioneer CT-W910R that Im rebuilding.Thankyou for taking the time to help me with this AnalogKid and the quicker than quick response.lol
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    As mentioned in a recent similar thread Electrolytics have typically wide tolerance value of -0% to +100% by many manuf specs.
    Max.
  5. ScottWang
    Aug 23, 2012
    4,934
    777
    Wow, "-0% to +100%", could you link any one to see?
  6. ScottWang
    Aug 23, 2012
    4,934
    777
    What's reason to make you have this thought : use 4700uf instead of 3300uf capacitors?
    And what kinds of load are you always used?
  7. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    ScottWang likes this.
  8. PackratKing
    Jul 13, 2008
    850
    216
    [ I will likely catch hell for this] It seems to me, that when the given capacitor is still in production, it could / should be measured for its actual individual capacity, and then labelled accordingly...
    Yeah... I know... I've heard it all before... That would " Kawst teww Muuuch "
  9. dl324
    Mar 30, 2015
    3,391
    653
    Your right, that's a terrible idea. Capacitors, like resistors, have "standard" values with tolerances. Values for caps used as power supply filters are not critical and good designs take typical electrolytic tolerances (of -20% to +80%) into consideration.
    The tolerance figure I used is from what I've seen marked on components and/or documented in datasheets. For the questioning types, here are two online references that you can choose to believe (or not): electronics-tutorials.ws and radio-electronics.com
  10. dl324
    Mar 30, 2015
    3,391
    653
    Out of curiosity, I searched; P tolerance is -0% to +100%:
    EIA cap tolerance codes.
    AnalogKid and ScottWang like this.
  11. ScottWang
    Aug 23, 2012
    4,934
    777
    What I can accept is quite normal that is from -20%~+20%, too much tolerance will make designs become more difficult.
    PackratKing likes this.
  12. RichardO
    May 4, 2013
    1,350
    432
    The only downside to using a larger capacitor value is that the lower ripple voltage can increase power dissipation in the pass transistor of the voltage regulator. This assumes that the cap is the same or better than the one it is replacing in all other ways.
    edit: I just thought of another potential problem caused by a larger capacitance value. The surge current charging the cap will be larger. This could strain the rectifier diodes.
  13. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    It also increases the VA required value of the transformer if used at the maximum current rating.
    Max.
  14. ScottWang
    Aug 23, 2012
    4,934
    777
    Have you even really use the tolerance equal or over +50%?
  15. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Have you ever measured some of the larger capacitors for value?
    In most applications I have used it is not a problem, it may even be an advantage!
    Max.
  16. ScottWang
    Aug 23, 2012
    4,934
    777
    When I measured the big capacitors as 2200 uF and 3300 uF or 4700 uF, they are all in +0~20%.
