Higher Freq 555 timer oscillator
Discussion in 'General Electronics Chat' started by CraigNS, Mar 25, 2012.
  1. CraigNS
    Sep 23, 2010
    I've been trying to create an oscillator using a 555 timer in astable mode. I want an output freq. of about 150 khz. Using a scope I can see as I start reaching the higher frequencis my ac waveform is left riding on a dc bias and by the time I get to 150 khz I'm only getting about 30 mv change in my oscillation and it's quite a messy sawtooth.
    Is this just a limitation of some cheaper 555 timers? I've read online where people have used these for freq. up to 300khz.
  2. w2aew
    Jan 3, 2012
    The 555 really isn't suitable for frequencies higher than about 100kHz in many cases. If all you want is an oscillator - then a simpler and easier solution for higher frequency oscillators would be to make a simple inverter-based ring oscillator. See this appnote:
  3. CraigNS
    Sep 23, 2010
    Thanks for your reply.
    Ya, I knew I could make one with a schmidt trigger, but don't have one lying around. Maybe I can scrounge it out of something.. otherwise I'll have to order and wait.
    Good to know about the 555 limitations I guess. Kind of slow really.
    Another option I guess could be a frequency doubler... hmmm
