High watt LED Project
Discussion in 'The Projects Forum' started by keaster, Sep 5, 2013.
  1. keaster
    Apr 28, 2013
    11
    I'm working on a project using a cluster of 3x3Watt RGB LED's. I found this simple CCS http://www.instructables.com/id/Circuits-for-using-High-Power-LED-s/ to drive high watt LED's of single color and it works great, so I built a total of 3 to drive a 3watt RGB, now I want to connect 3 RGB's would I need to have 9 CCS or can I drive each color from 1 CCS? I read that when controlling current its best to connect in series but I can't with a common anode RGB.
    Any ideas?
  2. #12
    Nov 30, 2010
    16,657
    7,300
    Can you post a schematic of the circuit that you used?
    How much voltage do you have available?
    How many volts and amps does a 3 watt LED use?
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    I don't see a way that you don't need 9 CCSs. Maybe RGB LEDs are not a good choice for your project.
  4. keaster
    Apr 28, 2013
    11
  5. #12
    Nov 30, 2010
    16,657
    7,300
    Put a few LEDs in series and use one regulator to supply as many as you can, as long as the voltage needed for the LEDs is less than 11.2 volts.
    The drawing you posted looks just right.
  6. wayneh
    Sep 9, 2010
    12,368
    3,224
    #12, he's got 3 LEDs total, and each is an RGB with a common anode.
  7. #12
    Nov 30, 2010
    16,657
    7,300
    Ah...you mean the drawing does not account for the number of leads on each LED. Right?
    Something like this except this circuit gives no control over individual brightness?
