High voltage switches
Discussion in 'The Projects Forum' started by MarkJC, Dec 5, 2010.
  1. MarkJC
    Dec 5, 2010
    I'm working on a project where I need to be able to implement a switch capable of turning ON/OFF current flow in a high voltage circuit using a very small base voltage.
    The current flow that I need to control will be between 500V-2000V (~10-15mA current) and the base voltage that I would like to control that flow with will be only 3.3V (10-20mA current).
    I've come across two components I could use as switches - an NPN transistor or a solid state relay. Problem is, most of these seem to only be for low voltage applications. And in the case of NPN, I can't find one that has acceptable emitter-base and collector-base voltage limits. Can you recommend or point me to a source for components that might work for this project?
  2. mik3
    Feb 4, 2008
    4,846
    63
    An IGBT shall be suitable for your application, however, it needs 15V to its gate to turn on.
    Are you going to drive it by a microcontroller?
  3. MarkJC
    Dec 5, 2010
    Yes, that is the plan right now. Any thoughts on a way to get around the 15V turn on voltage at the gate? Is the gate voltage limited or power limited (where the combination of current/voltage matters)? I'll be dealing with DC so I guess that rules out a transformer.
  4. mik3
    Feb 4, 2008
    4,846
    63
    I guess you have a 3.3V microcontroller.
    You need to provide a 15V DC power supply by some means. Then I advice you to use an IGBT gate driver to drive the IGBT.
  5. Kermit2
    Feb 5, 2010
    3,854
    968
    most definately some form of opto coupled circuit would be of use here. DC isolation
