High voltage short duration switch for Pulsed Capacitor based magnetizer
Discussion in 'General Electronics Chat' started by knowtankyou, Feb 29, 2016.
  1. knowtankyou
    Feb 29, 2016
    32
    Hello, I would like to ask for some suggestions on components to use for making a high voltage magnitizer.
    http://www.instructables.com/id/How-to-make-your-own-Metal-Pulse-Magnetizer/?ALLSTEPS
    however rather than a simple push button across that voltage I would like to find a solid state solution that I could have close and then open at a time interval that is adjustable.
    so I can set it to energize for 0.5 sec, 1 sec, 2 sec, ect before pressing the button.
    I was going to use the 240V welding outlet in my shop as the source.
    I plan to make my own high voltage capacitors mostly following the steps that rimstar uses in this video.
    any other suggestions on making high voltage capacitors is very much appreciated.
    thank you for your time and have a good day
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    You want to magnetize with a pulsed coil, correct?
    A Silicon Controlled Rectifier (SCR) would be a good candidate as a switch.
    Note that the "high voltage capacitors" you intend to build will be useless, these have minute capacitance. (picofarads)
    You need a large electrolytic capacitor rated for the voltage. (hundreds of microfarads)
    Note that this project can kill you- be careful.
  3. knowtankyou
    Feb 29, 2016
    32
    thank you, i will be careful.
