High voltage, Low power supply reference design
Discussion in 'General Electronics Chat' started by mmuj, Apr 15, 2016.
  1. mmuj
    Dec 15, 2009
    11
    Hi
    I have to design a power supply as a part of a bigger system but I have no experience of high voltage power supply design.
    I am looking for a reference design for high voltage low/medium power, isolated power supply.
    Requirement specs are
    VIN Range = 150V to 650V, 50/60Hz, 400Hz is an optional
    VOUT = any thing between 24V and 48V
    Output Power = 50W
    Thanks and Regards,
    M Mujahid
  2. highvoltpower
    Apr 5, 2016
    12
    A power supply is design to provide large output voltage at low current. Your output can be regulated using the variable resistor on outside of the box.
  3. ScottWang
    Aug 23, 2012
    4,924
    776
    Could you draw a block diagram and describe some more details?
  4. mmuj
    Dec 15, 2009
    11
    I am looking for something like
    https://www.onsemi.com/pub/Collateral/AN1327-D.PDF
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,677
    1,294
    Looks like you found it. An input voltage of 920 Vpeak is unusual. It will limit your selection of input side components and increase the difficulty of designing the transformer. But other than that it is a 50 W converter, and there are plenty of designs on the innergoogle. Know in advance that the transformer will be 80-90% of the total project effort.
    Don't know what your efficiency, schedule, or budget limits are, but you might consider a hybrid approach. If you can find an off-the-shelf high voltage down-converter that has the safety certifications you need but the wrong output voltage, a secondary stage that is a non-isolated boost or buck to get the output you need can take a fraction of the design effort. Bigger, less efficient, more expensive, but a few weeks instead of a few months.
    ak
