High voltage-level shifter
iami29
Joined Aug 17, 2011
Hi,all
I have a pack of batterys in 16 series, general 3.6V/battery.
Now I want to shift up 0.7V at every positive electrode of battery.
i.e. Vbat1=3.6V-->4.3V
Vbat2=7.2V-->7.9V
Vbat3=10.8V-->11.5V
Vbat15=54V-->54.7V
Vbat16=57.6V-->58.3V
So is there any IC or circuit I could use?
Thanks!
Kermit2
Joined Feb 5, 2010
4,162
Is this a circuit to shift a reading up .7 volts, or do you need full current delivery from the battery at the shifted level?
IF you want full current capability at the shifted up voltage level, there is simply no way to do that with a 'simple' low powered set of circuit components. You would need high current power supplies for each and every position that you want to shift.
iami29
Joined Aug 17, 2011
Hi, Kermit2:
I don't need full current delivery from battery at the shifted level, I just need to deliver the voltage signals to other circuit.
