High Voltage Bridge Rectifier Diode Dilemma
Discussion in 'General Electronics Chat' started by carder, Mar 25, 2009.
  1. carder
    Mar 25, 2009
    I am building a 6kV power supply but I can't find diodes for the bridge rectifier, I have a 6kV, 260mA transformer.
    For this transformer I need 10kV diodes but the only ones I could find have the Average Forward Rectified Current of 350mA.
    Will these diodes conduct lower currents like 260mA?
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Yes. The given 350 mA is the maximum current allowed, more will break them.
    The 260 mA you stated is within the 350 mA, so they will work.
    Greetings,
    Bertus
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    They will work ok. Please be careful, as you are working with LETHAL voltage and current levels!
  4. carder
    Mar 25, 2009
    I will be careful
  5. donatosd
    Member
    Mar 31, 2009
    13
    can you tell me which diodes you have found? from where?
    thanks
  6. Darren Holdstock
    Feb 10, 2009
    262
    11
    Check the diode datasheet carefully - sometimes high voltage diodes are designed to work only when encapsulated in serious insulation (silicone sealant is good at HT, but don't use the stuff designed for bathrooms). The diode terminals can flash over if they're left exposed in free air.
