First off, Hi to all in the community! =)
this is my first posting. I'm an undergrad physics student and I need to build a high voltage amplifier that is, I need to turn an input signal(sawtooth 0 to 10 V pk to pk) from a function generator into an output signal : 0 to 100 V peak to peak at maximum gain.I also need a gain adjustment knob. I should also mention that output current needs are minimal as in they are in the fractions of a microampere range.
I'm sort of a noob in circuit development and I'm in desperate need of suggestions and advice! Currently I'm planning on achieving this by using an HV opamp such as http://www.cirrus.com/en/pubs/proDatasheet/PA240U_G.pdf but i'm not sure if that is the best choice. I'm planning on setting a basic non inverting configuration and again I'm not sure if thats the best design. I have attached a copy of the schematic. Please let me know if what I've drawn is correct. Any suggestions or advice is greatly appreciated..
