High voltage (-150V to +150V) sweep generator
Discussion in 'General Electronics Chat' started by dren qerimi, Aug 1, 2016.
  1. dren qerimi
    Aug 1, 2016
    Hi everyone,
    I am trying to build a high voltage (-150V to +150V) sweep generator. Can someone help me out, I am not very good with circuits?
    Thank you
  2. BR-549
    Sep 22, 2013
    2,164
    415
    Why.
  3. dren qerimi
    Aug 1, 2016
    I am trying to read plasma voltage inside vacuum chamber, I usually do it thru an oscilloscope but I want to build/buy a circuit and make a code so I can in-situ read it from the PC directly.
  4. DickCappels
    Aug 21, 2008
    2,746
    665
    Sounds like a nice project.
    When you start talking about ±150V you are talking about slightly specialized parts. Do you already have power supplies to support this? If not, in what part of the world will you be buying parts?
    How do you expect the voltage to vary over the range -is it a free-running triangle/ramp generator, is it DAC driver, or by another means?
  5. dren qerimi
    Aug 1, 2016
    Well, I make Langmuir probes which are devices to measure electron temperature and electron density of plasma ( ionized gas) inside vacuum chambers. The principle behind this device is very simple since its a diagnostic tool. We have very big power supply, up to 30kV with currents up to 10A. I usually do this using an oscilloscope but I wanted to build a circuit of my own and connect it to computer directly.
  6. ScottWang
    Aug 23, 2012
    4,924
    777
