High temp solder
Discussion in 'General Electronics Chat' started by Dr.killjoy, Jun 25, 2013.
  1. Dr.killjoy
    Apr 28, 2013
    1,210
    158
    I found an old Hakko element for my Hakko 907 iron ...But my problem is that I have use a torch to solder the lead to the ceramic element because the wiring is different but what kind of solder can I find locally in order to solder these wires and able to handle the temps ????
    I was thinking about using silver solder but not sure if that was a wise choice and i only need a small piece too....
    JAy
  2. chuckey
    Jun 4, 2007
    75
    10
    Silver solder needs borax flux and heating to dull red heat.
    Frank
  3. #12
    Nov 30, 2010
    16,704
    7,354
    What temperatures?
    I do brazing, I do all sorts of melted metals, but I don't know what you want.
    A propane tank can be fitted to a soldering tip. That would keep flame from splashing all over the object of desire. Lower temperature is a soldering gun, Weller 140W or 250W. Higher is Mapp gas, then oxy-acetylene. I have all of these, but I don't know what to recommend.
    Keep talking.
