High-speed widerange voltage to current converter
Discussion in 'Analog & Mixed-Signal Design' started by prof_zlyh, Aug 29, 2016.
  1. prof_zlyh
    Aug 29, 2016
    Hello.
    I have differential voltage signal, which represents pulses. Form of this pulses can be rectangular, gauss, exponential and parabolic. Duration of this pulse can be between 50 and 1000 ns. Rise time and fall time of rectangular pulse 2-5 ns. Amplitude of this pulses can be between 10 mV and 2.5 V. I need to convert this voltage pulses to current pulses with amplitude (current signal also should be differential) from 10 nA to 1 mA. Furthermore, output of this converter should be isolated from external circuit, because there is high voltage (about 300 V). So, i need high-speed wide-range voltage to current converter. Do you have any suggestions?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    How About a resistor in series with a transformer?
  3. AlbertHall
    Jun 4, 2014
    2,261
    447
    The transformer will need to be a bit special to handle the pulses faithfully.
    What is the output impedance of this voltage source?
  4. prof_zlyh
    Aug 29, 2016
    Output impedance is 50 Ohm.
