blueroomelectronics
- Joined Jul 22, 2007
- 1,757
But you haven't answered the question. Is it an overunity project you're working on? If not what is it supposed to do?
Typically, when the question is dodged, something similar to what was asked is true.But you haven't answered the question. Is it an overunity project you're working on? If not what is it supposed to do?
I just can't figure out what it's supposed to do. And why a square wave?Hi kubeek, Im going use this 1 GHz square wave as an input battery to my biasing circuit. So I have a device generating sine wave at 1 GHz, so I need to convert it to a square wave. I am not really sure about rise and fall time, cause Im not sure how it will help it to work like a battery.
Is your semiconductor optical amplifier a part that has a datasheet? If so, can you publish a link to it? If you have an app note or datasheet that talks about the bias you are contemplating, that would be helpful also.Guys guys guys, chill out, im sorry, i was working in the lab. This square wave signal will work as a battery to the bias circuit to generate a non-uniform bias current as a supply current to semiconductor optical amplifier to reach its most optimized performance.
semiconductor optical amplifier is an optical device used for switching and amplifying and modulating as well.
I will get back to you guys once I finish testing my circuit. Sorry guys and thanks a lot for the ideas! Sorry again!
Ok so what is the OP building?Its not that complicated. You don't need a square wave, you need a detector. At 1.5 GHz, you can use a low capacitance Schottky diode followed by a capacitor. Try an 1N5711 and a 100 pf capacitor. If that doesn't get you enough voltage, you can try adding a tuned stub as a high resonant circuit to try and boost the voltage, but be aware that such a circuit will perform poorly if heavily loaded.
by Duane Benson
by Jake Hertz
by Aaron Carman
