Howdy!
I'm anything but well versed in electronics, but I do have a basic understanding of ....basic stuff. So, I figured I'd solicit those of you who know a lot more than me to help me with a problem...hopefully.
I've built a digital counter for the purpose of tallying rotations on my metal lathe. The reason I need to do that is that I wind guitar pickups, and the tonal characteristics of a pickup are determined in large part to the number of wraps of magnet wire.
I made the counter itself from a digital pedometer by removing the mechanical pendulum, and soldering leads from the necessary points on the PCB and connecting the leads to a micro reed switch.
I placed a strong NIB magnet on the rotating pickup bobbin holder, and by means of a home made holder, placed the reed switch in close proximity to the rotating piece.
It works, but only until I get to around 150 RPM, then it starts skipping or missing turns. I figured that out by using my built-in digital lathe tachometer and a stop watch to calculate an expected number of turns over a 60 second period at various RPM's.
I'm guessing that the problem is contact "bounce", but I have no idea how to overcome that with a micro reed switch. I've heard that adding a small value capacitor to the circuit might help, but I don't know where to place it in the circuit (in series or parallel, before or after the switch, etc.), the value.
Could it be rel;ated to the pedometer's ability to keep up? If so, any ideas on what might be a better device to use? Maybe a calculator?
I need the counter to keep up at 400 RPM's ideally (the fastest I can safely guide 42 guage wire without it breaking).
Any help or advice is GREATLY appreciated!
