high speed clocking in of data FIFO question
Discussion in 'General Electronics Chat' started by baringforge, Nov 30, 2010.
  1. baringforge
    Nov 30, 2010
    I'm mainly a software guy, with enough hardware prototyping experience to be dangerous :) I have an application I'm working on where I want to clock in serial data from a device at 4 Mb/s. I tried adding a shift register in, but I still get 4,000,000 / 8 interrupts per second to my poor little Coldfire cpu.
    I'd like to incorporate a deep fifo in the mix so I can go out and read in a bunch of data once in awhile via dma on my data bus or whatever. Something like a "Serial to parallel fifo", like the IDT72142 would be pure gold, but it's obsolete, probably because everyone uses FPGAs nowadays. Does anyone know of a good way to clock serial data into a fifo, then pull it out in parallel (8 or 16 bit)? I was thinking about doing an FPGA, but I'd like to just drop in an IC and get this done.
    Thanks !
  2. retched
    Dec 5, 2009
    5,201
    313
  3. baringforge
    Nov 30, 2010
    Thanks for the reply. It could be that I'm lost, but I'm not sure that using a 74hc594 buys me much more than I already have. I'm already using a shift register (74hc164). I'd like to be able to buffer up at least 4Kbit so I only have to pull out data at 1ms periods.
    I've got a:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=800-1507-5-ND
    This is a neat 2048X9 fifo, but I can't get from my shift register into that, so I was hoping to find a fairly deep fifo I can populate serially.
  4. baringforge
    Nov 30, 2010
    It's kinda weird. There doesn't appear to be any SIPOs available anywhere, by anyone. It seems like there would at least be a market for these things.
  5. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    That's because the capability is inherent in most programmable devices, manipulated with simple software routines/switches.
