High side Mosfet driver using n-channel
Discussion in 'The Projects Forum' started by jonfarrugia, Jan 5, 2014.
  1. jonfarrugia
    Feb 19, 2010
    20
    I've been looking at different ways to control an N-channel mosfet as a high side switch for a 12VDC load.
    The signal to the circuit will be from an arduino it may or may not be a pwm output.
    I was considering using an LM2941CT set for 20vdc as the power for the MOSFET gate driver circuit.
    If I connect the arduino output to a transistor that controls either 20vdc or 0vdc to the high-side n-channel MOSFET gate, would this be ok? See attachment
    I was going to use this regulator because I want to use it's power to drive 20 MOSFET gates from 20 different Arduino Outputs.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    That looks right, give or take frequency related parts. Depends on how fast you want to run it.
  3. jonfarrugia
    Feb 19, 2010
    20
    at most it would be about 1khz - 5khz
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    There are a heap of specialist small ICs called "high side FET drivers".
    Many of them even generate the higher voltage needed for the gate, so you don't need dual PSUs. :)
  5. #12
    Nov 30, 2010
    16,704
    7,354
    As the gate is passing 12 volts, going positive, there is 8 volts across the 10K resistor. That's .0008 amps. The gate is 190 pf. The gate voltage will be moving at 4.2 volts per microsecond if I did the math right. The half wave time of 5kHz is 100 usec. That says more than 2% of the 5Khz time will be spent in the last 8 volts.
    I think, speed it up a bit. 750 ohms for R1
    Still, RB has a better idea.
  6. jonfarrugia
    Feb 19, 2010
    20
    Can u provide a link to a single ic driver that might work in this application?
  7. jonfarrugia
    Feb 19, 2010
    20
    Thanks. I'll test this when the components come in.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    Why not just use a PFet preceeded with an NPN? That also eliminates the need for a higher than 12V power supply or charge pump.
  9. jonfarrugia
    Feb 19, 2010
    20
    Can u provide a circuit so I can understand what you mean?
  10. #12
    Nov 30, 2010
    16,704
    7,354
    Or move the N-fet to the other side of the load.
    There are 6 ways to do this. Why you choose the most difficult?
  11. jonfarrugia
    Feb 19, 2010
    20
    I need high side switching for this application.
    I went with the above circuit cause I have the IRF510 MOSFET in stock.
  12. #12
    Nov 30, 2010
    16,704
    7,354
    Well, my answer (post #5) is in compliance with what you would probably have on hand.
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    Here it is without words. There are hundreds of PFets you could use for this application.
  14. #12
    Nov 30, 2010
    16,704
    7,354
    That pretty much confirms my math. The MikeML circuit has 3usec time one way and 8 usec time the other way. That demonstrates that a 10K drive resistor is going to be awful in this application.
