High Side High Voltage Current Shunt Monitor
Discussion in 'General Electronics Chat' started by masa6614, Jun 17, 2010.
  1. masa6614
    Thread Starter Active Member
    Nov 9, 2008
    49
    I'm wondering if anyone knows of an amplifier IC for current measuring across a shunt on a 1200VDC high side line? Maybe even with an isolated output
    I cant seem to find any with a very high common mode voltage range,
    http://cds.linear.com/docs/Datasheet/4151fb.pdf
    http://www.analog.com/static/imported-files/data_sheets/AD8212.pdf
    http://www.diodes.com/datasheets/ZXCT1080.pdf
    I know there must be something, if they sell 1200V IGBTs, how do they measure the current they're passing?
    Any help is greatly appreciated, Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
