High side driver problem
Discussion in 'The Projects Forum' started by rajeshkn, Aug 22, 2012.
  1. rajeshkn
    Aug 22, 2012
    Hello I need to select/design an high side driver for a motor that needs continuous drive(Not pulsed operation). The motor has coil resistance of about 200mΩ, inductance of 130uH. supply voltage is DC 6V~16V, starting current limit should be 30Amps, normal operation current is 15A~25A (continuous). The motor need dc supply current. The supply requirements for motor is: Motor on->5 seconds, Motor off->5 seconds, this has to repeat for 20 minutes (total 120 times motor on, 120 times motor off) and then there will be a long pause.
    Please suggest any idea. I need something like a constant current source which can supply 15A to 25A current (continuously) (And start up current should be <30A is important)
    Some additional desired features are
    Short circuit strength to power supply and ground, line breakage, excess temperature of the power output stage, Current monitoring,drive must have a temperature sensor for diagnose the temperature of the driver for a range of -40°C to +200°C.
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Be smart and use a smart High side switch. Makes it much easier.
    http://www.ebay.com/sch/i.html?_nkw=bts+650
    Drive it with 5 second astable multivibrator and a monostable of 20min.
    Are you sure you need a constant current source? According to your description the current changes, so it's not constant. Maybe you mean a current limit when it gets to 25A, i.e. the supply voltage decreases when reaching 25A?
    rajeshkn likes this.
  3. rajeshkn
    Aug 22, 2012
    Thank you for you reply.
    Word constant current source was not appropriate there.
    For me the nominal load current required is about 15A to 25 Amps. BTS650 support about 17 Amps (typ) only.
    Should I choose heigher current rated smart High side switch?
    They are bit expensive at higher currents.
    Is BTN79XX half bridge are cost effective solution as they support higher load current?
  4. praondevou
    Jul 9, 2011
    2,936
    489
    You just need a proper heatsink. The 17A is for PCB mounted components on a 50mmx50mm copper area without air flow.
  5. rajeshkn
    Aug 22, 2012
    So can I still use BTS650 component for load current up to 25A by using proper heat sink? Will the device work?
  6. praondevou
    Jul 9, 2011
    2,936
    489
    It should work. It is specifically suitable for this kind of application.
