I am looking at building a circuit to measure some high resistance values. The resistances I want to measure range from 200kOhms to around 10,000MOhms.
The first thing that comes to mind is a voltage divider. I am thinking about having a few different resistors to measure the different voltages at the divider. Then rearranging the voltage divider equation for the high resistance I could find its value.
As I am intending to use as low voltage as possible (maybe 5V?), at the high resistance values, will I be able to measure any voltage? I could possibly step up the voltage, however I have limited space for this circuit.
I haven't tested this practically yet, just running through some ideas. Is there any other possible circuits anyone knows of to measure resistances on the order of 10,000 MOhms?
Cheers,
Sean
Cheers,
Sean
