High Power Switching Power Supply
Discussion in 'The Projects Forum' started by Ilmarj, Jan 6, 2012.
  1. Ilmarj
    Jan 6, 2012
    Hi.
    I have a need to construct a high powered switching supply for my 500W solid state linear amplifier. The supply needs to have a 120VAC input and a pretty clean 40VDC 20A output. Has anyone dabbled with such an animal or can lead me to a circuit I can modfify for my needs? Your help is greatly appreciated!
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    re-edit: At first, I suggested hooking a few ATX computer power supplies together in series to get your output needs, and then I flip-flopped, deleted that comment that used to be here, and suggested a linear supply below. Upon receiving the next comment by bountyhunter, I flip-flopped again after thinking the ATX supplies through in a separate response.
    Big transformer, big rectifiers, big caps. Designing a switch-mode power supply that can safely and reliably deliver 800 watts would be quite an undertaking. Any stereo receiver rated for wattages that high usually has a FUSED unregulated DC supply in it as well...at least, they used to.
    Alternatively, you could go this route:
    http://www.antekinc.com/details.php?p=270
    or something similar.
    Good luck!
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    That's an 800W power supply. We built them and I can tell you that you can buy them way cheaper than build them. You could use a half bridge but peak switch currents would be very high. I would use a four FET full bridge offline design if I had to build one. The idea of kluging one together from PC supplies might work (?)
  4. PaulEE
    Member
    Dec 23, 2011
    423
    32
    I liked the ATX supply idea because:
    1) They're completely idiot proof (which is good for me; I always inevitably short the outputs accidentally)
    2) They're mass-produced and are quite affordable
    3) They're already designed and come in a neat little box
    4) They've proven themselves to be reliable in computers for years
    5) It's an excuse to order from Newegg or TigerDirect (har har har)
    6) They're pretty darn quiet (noise on output power), considering they power computer components
    7) They're easily mountable with pre-drilled standard holes
    8) They're not a heavy, bulky, expensive linear supply
    I would still hook one or several giant capacitors on the output; I don't know how a computer power supply would act under an abruptly high load...similar to abrupt bass in audio...computers tend to change their load requirements slower...or, at the very least, they're more constant with time than an audio amplifier supply load would be.
    Enjoy
  5. kubeek
    Sep 20, 2005
    4,687
    805
    PaulEE: there are also some cons of ATX´s:
    You need to modify them to make the outputs floating, so that you can safely connect them in series. Not a hard task, but still..
    As for the large capacitors on output, how do you think the PSU will react on startup? Most likely the overcurrent protection will kick in before the caps even start to charge, so you would need some soft-start to let them charge before you turn the amp on.
    PaulEE likes this.
  6. PaulEE
    Member
    Dec 23, 2011
    423
    32
    All good points. I'm angry with myself for not thinking through the capacitor bank downfall. Soft-start would solve that, though.
    In my head, I was modeling the supplies as batteries, one after the other. Can you describe how you'd "make the outputs floating"? As far as I know from taking them apart, they're just buck converters, which, in the simplest case, has the switching circuitry, inductor, and capacitor. The cap is what has the output voltage impressed upon it...not sure what the issue is with simply hooking them up in series.
    Anxious to hear your thoughts.
  7. kubeek
    Sep 20, 2005
    4,687
    805
    The issue is that the ground on the secondary is typically connected to the metal case and that is connected to mains protection earth. You try to connect two in series, you short the lower one through the earth loop.
    To make it work and still be safe you need to disconnect the ground-protection earth connections on all but one supplies, so that the total series combination is still safely grounded at one point.
    PaulEE likes this.
  8. PaulEE
    Member
    Dec 23, 2011
    423
    32
    Excellent. Thank you for that.
    And,
    "being onto it" was supposed to be "impressed upon it" in the post before last.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    First, get a 120 to 40V step down toroidal transformer with center tap, or It needs to be rated at 500VA.
    Then rectifier, center tap is ground, add several large capacitors to +20V and -20V rails.
    I found ±25V from 120V, 500VA That would filter to a bit over ±30V, but give you more dynamic headroom if the amp is built properly.
    Reason for toroidal is to keep EMI/60hz "hum" from crossing over to audio section.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    I'll speak the heresy: IMHO, the power rails used in an audio amp don't need to be regulated, so they can be generated the old fashioned way: a big honking transformer followed by rectifiers and giant capacitors.
    I also don't see why any power supply running an audio amp would need to be able to supply rated power CONTINUOUSLY since average power of music is typically about 1/20 or less of peak power.
    just my opinion
  11. kubeek
    Sep 20, 2005
    4,687
    805
    true for typical class AB setups and similar. D-class is more sensitive and some have poor PSRR.
    Depends on what the amp is used for, for example my bass guitar amp on a gig could be under full load 50-80% of the time I am playing. On the other hand a home stereo surely doesn´t need fully rated supply at such powers.
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
  13. PaulEE
    Member
    Dec 23, 2011
    423
    32
    That's two votes for honkin big transformer, rectifier, and caps! :)
