High power regulator
Discussion in 'The Projects Forum' started by kader_farooq, Apr 16, 2009.
  1. kader_farooq
    Apr 16, 2009
    Need 70Amps 110 Volt Regulator.. Any one the best way to make using shunt type? Waiting for uour answers.
    Kindly attach circuit design and diagram
  2. mik3
    Feb 4, 2008
    4,846
    63
    Search for switch mode power supplies.
  3. AchMED
    Aug 5, 2008
    41
    Code ( (Unknown Language)):
    1. Need 70Amps 110 Volt Regulator.. Any one the best way to make using shunt type? Waiting for uour answers.
    2.
    3. Kindly attach circuit design and diagram
    4.
    5. Thanks
    P= E x I
    So you want a 7.7KW PSU?
    You cant get anywhere near that power level off a residential service even with a front end APFC the best you could get is about a quarter of that. You may be waiting a while!
    I also would like a 10kW PSU schematic,art work and BOM and my own mini substation.:)
    Waiting for your replies!
