HIGH POWER LED Drivers
RodneyB
Joined Apr 28, 2012
697
I have 3 LED's which I need to build drivers for.
1. 3500mA 30-34 Volts
2.700mA 30 - 34 Volts
3 1050mA 30 -34 Volts
I was Going to use a constant voltage power supply, but now I need to add the LED driver. The mean Well range offer a 700mA and a 1000mA but have no idea what to use for the 3500mA
Denesius
Joined Feb 5, 2014
124
The Meanwell units list for $60+USD. Try some of the units direct from Chinese manufacturers, available for less than $10USD. Some examples are at LED World via their ebay store at http://stores.ebay.com/ledworld2010professionalleds?_trksid=p2047675.l2563
Make sure the unit you get has overload protection. Many of the cheaper units will instantly overvolt & burn themselves out if there's no adequate load on the output.
