High power led driver
Discussion in 'General Electronics Chat' started by circuit1234, Jan 7, 2015.
  1. circuit1234
    Jan 7, 2015
    22
    Hi
    I want to make led driver which can drive 110v and 12Amps output DC to DC . for that i choose LT 3795. Should be constant current . can this driver drive these much power , which topology i need to use and is there any other driver
  2. ronv
    Nov 12, 2008
    3,398
    1,455
    :cool:What are you trying to do? Light a football stadium? :cool:
    Maybe 100 volts at 12 amps.
  3. circuit1234
    Jan 7, 2015
    22
    Hi Ronv
    its a series of led , we need to do some testing , for that we need to design LED driver Which can drive 1kw Power.
  4. ronv
    Nov 12, 2008
    3,398
    1,455
    Hmmm. I think if I was going to try it I would build a simple hysteric buck converter.
  5. circuit1234
    Jan 7, 2015
    22
    Which IC you prefer i need constant current , and Ref voltage pin for adjusting the current , ( somthing which i can control using DAC)
  6. ronv
    Nov 12, 2008
    3,398
    1,455
    Ahh, Now you are making it harder. Maybe a spec is in order. What output voltage and current to the LEDs.
  7. circuit1234
    Jan 7, 2015
    22
    Actually output we need is 120volt, 12Amps DC , since the LT3795 cannot handle this much we reduced to 95Volt .
    So OUT PUT we need is 120Volt , 12Amp DC
  8. ronv
    Nov 12, 2008
    3,398
    1,455
    But you just said you wanted to adjust the current. What is the min and max current? Like wise if you want to use 5 leds and 25 leds it will make a difference.
  9. circuit1234
    Jan 7, 2015
    22
    its 2amps to 12Amps , Voltage 5Volt to 120Volt
  10. ronv
    Nov 12, 2008
    3,398
    1,455
    I think you will have trouble finding something. The one you have chosen might run from 15 volts to 100 volts at 2 to 12 amps, but pretty complicated.
    Maybe you should tell us what you are trying to do as the requirements seem very strange - even dangerous.
  11. circuit1234
    Jan 7, 2015
    22
    We are trying to design LED Driver which can use for driving many types of LEDs . Actuall purpose is for testing the LEDs life .some are in tile with a series of LEDs in that case the voltage will change and depends upon the led type current will change .
  12. toffee_pie
    Oct 31, 2009
    162
    7
    12Amps.......
    do you know how high 12A is? why the need for this much?
  13. circuit1234
    Jan 7, 2015
    22
    its a module which contains lot of small leds , any driver which you know?
  14. ronv
    Nov 12, 2008
    3,398
    1,455
    You may need to break down your requirements. It is unlikely you can make one that will run at both 5 volts and 120 volts let alone vary the current from 2 to 12 amps.
    I'm going to guess you biggest one is 100 watts - maybe 37 volts at 3 amps? Give us some data sheets on say 3 with a broad range that you want to test and maybe we can come up with a way to switch the input or something like that that will still make it flexible.
