Hello Everyone,
I'm not sure how to handle the low pass filter characteristics from the voltage divider to get 6V.
Why? The existing opamp already has an extremely high input impedance the same as a buffer.1) Is it likely I need to use a buffer op amp between the bias point and the R2 and R6 resistors?
C7 also has a fairly high value and will usually be a polarized electrolytic type.2. I have polarized caps for C8 and C4 in the revised diagram. I am guessing those are the only two that need to be polarized?
No.. In the revised schematic, is it acceptable to change C3 to 0.1uF and C4 to 10uF? The cutoff frequency then becomes 3.15 Hz
If you have hum then the value of C4 should be high. If the biasing resistors are 100k each then C4 can be 33uF. Then it is a good filter to reduce the hum.What about if I use 100K resistors for R3 and R4 with C3 = 0.1uF and C4 = 10uF?
The opamp has a low output impedance which is important. But what is the impedance of a 33uF filter capacitor at 35kHz? Only 0.14 ohms which is almost the same as the opamp. So the buffer opamp is not needed.1. I thought a buffer op amp was important based on what I read here on page 332
and shown in this schematic:
Do you think I need it in my particular case?
At 35kHz, a 10uF capacitor has a reactance of only 0.46 ohms. But the minimum load for the circuit is only 1k ohms so a 0.022uF film capacitor will be fine. A 0.1uF film capacitor can also be used. Besides, a ceramic capacitor is a microphone that picks up vibration, plus it adds distortion.2. For C7, I looked on Newark.com and they have plenty of 10uF ceramic capacitors rated at 25V. Is it likely I can use one of those instead of a polarized one?
C8 is 0.1uF which is good for high frequencies and C9 is 10uF (or 100uF) which is good for low frequencies. Then C9 is not needed.3. Does it hurt to leave the C9 1uF capacitor? Someone told me to use those three bypass capacitors off the 12V supply to filter a wider range of noise.
A battery does not produce hum so C4 is not needed.4. The circuit is powered by a 12 volt battery. The same 12 V battery powers a preamp circuit that feeds the signal to this circuit. It seems like hum would not be an issue but it doesn't hurt to assume it is? So I should use C4 = 33uF and C3 = 0.1uF?
C3 simply filters the bias voltage at high frequencies. At 35kHz its reactance is only 46 ohms but it is in parallel with C4 that has a lower reactance. Both do not affect the cutoff frequency of 35kHz.5. How come C3 doesn't come into play for the cutoff frequency calculation? It seems to me like 1/(2*R*C) should use the parallel of R3 and R4 (50kohms if both are 100k resistors) to get R and the parallel of C3 and C4 to get the C value.
In this case buffer doesn't help to much.I thought the buffer op amp makes the equations/analysis easier from what I had read. With the R3, R4, C3 and C4 components there is no effect on the resistor and capacitor values C1,C2, R1, and R2 to achieve a 35 kHz high pass cutoff?
Simply, all AC current will be shorted to the GND by low impedance of a 33uF filtering capacitor.I'm confused how the high impedance of the op amp pin and the low impedance of a 33uF filtering capacitor of 0.14 ohms at 35kHz allows for the values of the C1,C2,R1, and R2 components not changing.
Op amp distort much heavier when output load is increased.I see you mentioned the minimum load for the circuit is 1k ohms. Does that come from the spec sheet for the op amp or how is that value determined? The reactance of the capacitor at 35kHz just needs to be under 1k ohms? Why is that important? Is it just so the load impedance is higher for proper signal transfer?
You can leave C4 = 10uF if you want.I am going to use batteries to power the preamp and this filter but there is a chance in the future I may use a DC-DC converter if I use a single battery to power other components that are not related to the preamp or filter. Is C3 = 0.1uF and C4 = 10uF better than just using C3 with 0.1uF in case of any noise effects from the DC-DC converter or components powered by it?
Normally we don't use any extra resistor.I had read somewhere for unity gain amplifiers sometimes it is better practice to use a resistor for feedback instead of none. Is it likely needed with the op amps I am using for this circuit at unity gain? If so what resistor size makes sense for this op amp?
Input resistance should be at least 10 times greater then source output resistance.Should I worry about an input resistor, like in the preamp circuit I had posted on the other forum? Not sure what value to use if so.
No,Should I worry about an output resistor after C7, like in the preamp circuit I had posted on the other forum? Not sure what value to use if so.
But maybe the next stage has a pull down resistor.4. I'm guessing a pull down resistor after C7 is a good idea?
Use tantalum capacitor or electrolytic. Or use high load resistance then you can use film capacitor.I have a general question for C7 not related to the filter circuit. If I want to use a capacitor to block a DC offset but still want to work at low frequencies such as a 50 Hz or higher, then a larger value capacitor such as 10uF is a better idea. Should I use a polarized tantalum capacitor instead of a ceramic if I need a value that large and am dealing with a signal in the 50 Hz to 150kHz range? The reason I ask is that perhaps I want to bypass the filter circuit in some instances and just use the preamp at frequencies below the 35kHz. This means I need to keep a 10uF capacitor on the preamp output to block the DC offset.
by Aaron Carman
by Jake Hertz
by Duane Benson
by Aaron Carman
