Here's a very strange problem I've come across. I need to shift a high-frequency (50 kHz - 10 MHz) 5V amplitude square wave signal down to -100V, in order to drive the gave of a MOSFET. I did this with a high-pass filter:
This works fine at high frequencies, but for some reason not with low frequencies. In this case, 200 kHz.
I measured the voltage at IN+, and as you might expect, it is a clean 200 kHz square wave.
HOWEVER, when I measure the voltage at V3.pin1 (between C5 and R8), I get this horrible thing (200 kHz):
This doesn't make any sense to me. It's a high pass filter with a cut-off frequency of 1.5 kHz, why is it doing that?
Does it have something to do with the gate-capacity? Or Miller capacity?
Here's the entire circuit:
http://imgwiz.com/images/2013/05/06/BJgDu.png
The signals IN+ and IN- are as follows (5V digital):
Thanks for any help you can give me. If you need more information, I'll be happy to supply it.
