High pass filter - detailed explanation
Discussion in 'Homework Help' started by grushka, Feb 3, 2009.
  1. grushka
    Feb 3, 2009
    So I have this filter:
    and I plot ratio of Vout/Vin versus frequency:
    (there are 2 curves, as one represents simulation and the other one measurements obtained during the laboratory exercise)
    Could some please explain to me what is exactly happening in this filter step by step? I know there are 2 resonances at f=1300 Hz and f=2400 Hz, I know what a high pass filter is, what it does and now I need very detailed explanation for this circuit, like for a complete noob. Feel free to include some complicated formulas, I'm not afraid of them:) The most important thing for me is to know why it happens and when, not what happens as this is quite clear.
  2. KL7AJ
    Nov 4, 2008
    2,043
    293
    Not all filters operate at resonance (although some do, most notably the Cauer Elliptical filter and its derivations).
    It's best to think of a filter as a reactive voltage divider, with two reactive elements. Let's say you have a C and an L in series. As you increase the frequency, by the reactance formula, Xc=1/(2pi*fC), as the frequency increases, the reactance (impedance) decreases. At the same time, the Inductive reactance (L=2pi*fL) INCREASES, with corresponding increase in impedance. It's simple to see that the voltage at the junction of these two points will increase with increasing frequency.
    You don't have to know ANYTHING about the phase to explain it on this simple level.
    Hope that helps.
    eric
  3. grushka
    Feb 3, 2009
    well,I'm afraid it's not enough, I basically said the same thing to teacher and I heard "these are just a basic information, you're analyzing it on a surface level, students need to know more complex explanation". So no general rules which are obvious, but more deeper conclusions are needed this time...
  4. The Electrician
    Oct 9, 2007
    2,300
    335
    Do you know how to derive the transfer function, and then plot the poles and zeros on the complex plane?
    Having done that, you can draw some conclusions about the filter response from the pole-zero plot.
    Maybe that's what your instructor wants.
