High gain diff amp
Discussion in 'General Electronics Chat' started by automagp68, Nov 23, 2015.
Thread Status:
Not open for further replies.
  1. automagp68
    Nov 13, 2011
    81
    So i need to build a high gain diff amp. Only BJT,s available.
    need +- 7.5 Volt swing
    Typically i can't get a but diff amp to give me a gain of more then a 100 or so. I need 800 differential gain
    So the first thought is to cascade a few together. However, as the output voltage goes up and goes into the base of the next stage all i get is clipping.
    Say i built a single stage diff amp and then wanted to just get a bunch of gain out of it. Take the output and maybe run it into a Common emitter maybe
    How do i get the common emitter to not clip with a large input signal?
    Any other thoughts or proposed ideas on how to do this?
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Simple use diff amp as a input stage, next stage common emitter and finally stage (output stage) common collector.
    And CE stage will provide the most of a needed gain.
  3. automagp68
    Nov 13, 2011
    81
    Whats the point of the last stage?
    High output impedance? I only need to drive a 1k load?
    How do i keep the CE from clipping with an input voltage of a few hundred milivolts?
    Right now my diff amp is outputting around 700 mv with a 10mv input which I'm happy with i guess.s Now i need to crank up the gain.
    Will a CE take a 700mv input and no clip with +- 7.5 volt swing on a 15v supply?
    thanks for your input
  4. DickCappels
    Aug 21, 2008
    2,786
    676
    Most amplifier datasheets contain either a simplified or complete schematic of the circuit. Read and learn from them.
  5. automagp68
    Nov 13, 2011
    81
    Let me also say because this is a deign for a discrete chip i can't use a bypass cap for a CE
    Any ideas on how to do this?
    Without a bypass cap i am seeing low single digit gains
    I need a 7.5 volt swing. Frequency response is unimportant as long as it works for around 50k-100k
  6. Veracohr
    Jan 3, 2011
    560
    77
    You could do it like an opamp: design huge open loop gain & use negative feedback to set it where you need.
  7. automagp68
    Nov 13, 2011
    81
    Essentially what I'm doing is building the first few stages of an low grade op amp
    However i do not have the understanding to use feedback like an op amp does
    Needs to be done without that
  8. DickCappels
    Aug 21, 2008
    2,786
    676
Thread Status:
