high frequency sawtooth oscillator
Discussion in 'General Electronics Chat' started by DominusDRR, May 25, 2009.
  1. DominusDRR
    May 25, 2009
    26
    Is there a diagram of a high frequency sawtooth oscillator? 100MHz​
    I'm going to use HFA1109 Amp Op.​
    Fabián​
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    At that frequency it is going to be hard. You know how harmonics relate to waveforms, right?
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    Indeed....that's even pushing the recovery time of a xenon relaxation oscillator!
    eric
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps you could say why a sawtooth waveform is necessary?
  5. DominusDRR
    May 25, 2009
    26
    Yes. Definitely, I know about harmonics. I am not an expert in high frequency electronics, but I hope I will generate voltage signal​
  6. DominusDRR
    May 25, 2009
    26
    I need to generate this signal to compare with other lower frequency signal. Something like a PWM or SPWM
    Fabian​
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Why do you need 100 Mhz?
    What is the maximum frequency you use for the other comparing part?
    Greetings,
    Bertus
  8. DominusDRR
    May 25, 2009
    26
    The other is 1MHz @ 10 MHz
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thing is, you're frequency response is going to be way past 500Mhz. That is the 5X harmonic. For a decent waveform you'll need really high frequency response.
    At that frequency making a square wave is even harder, for the same exact reason. Square waves are usually used to generate triangle waves, but I think we can say this won't be practical at this frequency. The logic family ECL operates in this region, and gets around it by deliberately rounding the edges. A continuous logic chain in ECL resembles a sine wave more than a square wave.
  10. DominusDRR
    May 25, 2009
    26
    And.. a DDS. Is it best?
  11. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  12. millwood
    Guest
    that's an interesting design.
    1) the mcu takes usb signal and sends out i2c. I would love to see their source code, :) for that.
    2) the si570 is quite amazing. programmable oscillator. conceiveably, you can just take a mcu to control that with up/down buttons but controlling it with a pc through usb must be fun.
  13. millwood
    Guest
    the way they do tempco compensation is very smart.
    it looks like a well thought-out and well designed package.
  14. eblc1388
    Nov 28, 2008
    1,542
    102
