High frequency PWM dimming of LEDs?
Discussion in 'The Projects Forum' started by eem2am, Jan 12, 2013.
  1. eem2am
    Jul 22, 2012
    9
    We are wanting to do high frequency PWM dimming of the output of current transformers (which feed LED lamps) hooked up to a twisted pair bus.
    Do you think the “gap toothy” resulting waveform (see below) will be a cause of any problems?
    (This is a different question on a subject discussed elsewhere here)
    Block diagram………………..
    ….you can see the “shorting FETs which dim by stopping current flowing to the LEDs when the FETs are ON.
    We do NOT want to do low frequency PWM dimming, (~200Hz) because the low frequency of this dimming causes problems for the current source. (-it means the current source is switching from high power to low power output which causes problems)
    Therefore, we wish to do dimming at a much higher frequency (83.3KHz). But do you think that the resulting current waveform (as below, when D is not equal to 1) is going to mean problems?
    LED lamp current with no dimming (D = 1)
    LED lamp current with dimming with D = 0.083
    http://i48.tinypic.com/3ctas.jpg
    LED lamp current with dimming with D = 0.33
    LED lamp current with dimming with D = 0.92
    (Also, how would you reduce dissipation in the current source by correcting the power factor in the twisted pair?)
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    I don't think it'll be a problem. We'll see if someone else has a different idea.
  3. eem2am
    Jul 22, 2012
    9
