High frequency generator
Discussion in 'General Electronics Chat' started by Sparky49, Dec 2, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all,
    I have had a idea and would like to conduct some experiments on the idea.
    However, I need a very high frequency wave. As high as possible.
    At the moment, I cannot afford some of the ready made instruments, so I thought I would have a go (at least) of making my own source.
    May I ask what method would be best to produce the highest possible frequency signal? I'm not looking for huge amplitudes, really the only factor I'm interested in (at the moment) is a really very, very high frequency signal.
    Thank you very much for your time. I will try to remember to post the results of my experiments when they are done. I think they will be very interesting.
    We will see.
    Sparky
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    What range of frequencies are you looking for?
    How high is the highest needed frequency?
    What should be the frequency stability needed?
    Bertus
    Sparky49 likes this.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You can make a Gunn diode oscillator at about 10 GHz or so. In order to play in this sandbox you need instruments that cost as much as a house to figure out what is wrong when things don't work as expected. There's no free lunch and you can't get a lot for very little. Sound about right?
    http://en.wikipedia.org/wiki/Gunn_diode#Gunn_diode_oscillators
    Last time I checked the DX record at 405 GHz. was just over a kilometer using a big dish aimed with a 10x rifle scope.
  4. K7GUH
    Member
    Jan 28, 2011
    191
    23
    I can generate up to 25 watts output in the 902-938 MHz range.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    The blue-violet lasers in Blu-Ray discs and HD DVD drives emit at a wavelength of 405nm, which is a frequency of ≈740,000 GHz.:D
  6. PackratKing
    Jul 13, 2008
    850
    216
    really ??? 740 Tera-Hertz ??? :eek: Thatz one cookin' freq.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes. visible light is very high in frequency. Half-wave dipoles a just a bit impractical however, and connectors on that scale are also problematical -- ROFLMAO
  8. Sparky49
    Jul 16, 2011
    835
    417
    Ha, lol.
    "I am having trouble picking anything up"
    Thanks for the suggestions, they are all (mostly ;)) very good. I think I might go down the Gunn diodes.
    Many thanks! :)
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Remember not to look down the barrel of a Gunn diode. You might get powder burns.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    No, 2.45GHz is one cookin' freq.
    Sorry, couldn't resist.:D
  11. crutschow
    Mar 14, 2008
    13,482
    3,368
    Since you are talking high frequency, X-rays have a wavelength in the range of 0.01 to 10 nanometers, corresponding to frequencies in the range of 30 petahertz to 30 exahertz (3×10^16 Hz to 3×10^19 Hz). Perhaps you want an industrial X-ray machine? :rolleyes:
  12. Sparky49
    Jul 16, 2011
    835
    417
    Mmhmmm...
    They sound a bit long.
    Gamma rays should suffice. ;)
  13. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  14. PackratKing
    Jul 13, 2008
    850
    216
    Ron...........I'll shoot you next time.......................wait a dang minute..........this IS next time !!!! BANG !! :D
    Ron H likes this.
