High Frequency Electronics and radio
Discussion in 'General Electronics Chat' started by Robin Mitchell, Nov 7, 2014.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi all,
    I have always wondered something...
    I want to build a radio receiving circuit and wish to detect signals in the 100MHz region but this got me thinking. How can electronic circuits pick up signals greater than so many gigahertz? What frequencies can radio circuits really function at? What are the largest frequencies that electronic circuits can operate at? Can circuits really function at frequencies greater than 10GHz?
    All the best,
    Robin Mitchell
  2. crutschow
    Mar 14, 2008
    13,473
    3,361
    Microwave circuits are commonly used that operate above 100 GHz, with experimental circuits operating in the THz area. Of course at those frequencies you can't use wire to conduct the signals over any significant distance so some form of waveguide is typically used.
  3. flat5
    Nov 13, 2008
    403
    17
    There are oscilloscopes that can do analysis at 100Ghz.
    BTW, they are not inexpensive.
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    at 100 MHz a 3.5 Turns air coil has significant influence on the circuit.
    At 300 MHz, a PCB trace can be used as inductor.
    Generally, GHz circuits tend to be very small, and special structures are used on the PCBs, called microstrips.
    Above 10 GHz isnt used in consumer electronics as far as I know.
    100 MHz isnt difficult if you use Manhattan or "Dead bug" style on perfboard (with the copper side up).
    But above that, it gets more and more difficult, with 800 MHz or so being the margin what you can do with conventional circuit technology.
    flat5 likes this.
  5. ian field
    Oct 27, 2012
    4,447
    791
    Just past millimetre wave radar is longwave IR.
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    checkout J Chagdesh Bose ( I hope the spelling is right) he was working with milimeter waves back when marconi was working with long waves. He invented a lot of the stuff used today, waveguide, dielectric lenses, polarization shifting, p, and n type semiconductor detectors and a lot else.
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  8. ian field
    Oct 27, 2012
    4,447
    791
    In the earliest ventures into experimentation with Hertzian waves, no one had any notion of winding coils - the nearest anyone had to inductance was a hoop of metal.
    It was basically UHF and up.
  9. takao21203
    Apr 28, 2012
    3,577
    463
    Did you find this info on wikipedia? Can you cite any sources?
  10. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  11. ian field
    Oct 27, 2012
    4,447
    791
    Can't remember where I read that - probably an e-book or magazine article on the history of radio.
