Hi everyone, a question from Australia.
A couple of years ago at work, I rescued three very nice PSUs ordered incorrectly and destined by the powers that be to be thrown out.
They are Schroff Maxpower 124 units and I wish to use one of them to construct a polystyrene hot wire cutter. The data sheet for these is found here:
http://docs-europe.electrocomponents.com/webdocs/0ef8/0900766b80ef89cb.pdf
To work correctly, a cutter requires the ability for it's PSU current to be regulated so as to set the correct heat of the wire. I have had a bit of a look around for a circuit to achieve this however could not find one specifically for 24V.
It appears to my untrained eye that the current is set to 4.2A, but then it makes mention that over 50degC the output current should be reduced. Does anyone have some advice on a simple external current regulator circuit for this unit, or whether it can be regulated using it's native connections?
Also I do not need three of these units, so if anyone is interested in one or two of them, make me a reasonable offer (they are unused and still in their original factory plastic wrap). If someone wants all three, perhaps I will just use the cash to buy a decent variable current PSU and save the mucking about.
Any comments would be much appreciated.
Cheers!
Cheers!
