I have a 12V power supply and I need to obtain two poles with positive and negative voltage. The polarity inversion needs to be controlled electronically.
It does not matter what voltage I get, as long as the two poles are symmetrical (+V, -V) and that I can drive high current through them, several amps (currently 4-5).
A simple voltage divider won't do because the resistors involved will limit the current and my load is around 3 Ohm, so even a small resistance added will have impact on the circuit.
The only solution I have so far is an H-Bridge (which works since I don't need both polarities at once), but I am looking for something simpler.
Any ideas?
Any ideas?
