I'm using about an inch of wire about the size of an average connecting wire used in breadboard.If the voltage at the Peltier is less than the supply voltage then there's a voltage drop between the two.
What size and length wires are you using to connect it?
Note that the ammeter itself has some resistance.
I did charge it at for about 3 hours with 500ma current.. Is it considered dead when the voltage drop is 10.1V when the peltier is connected? I only used it for about 10 mins.Measure your battery under a light load. If the voltage is below 10.75, you need to do an initial charge on the battery.
Visit the battery university website to learn more about the care and feeding of your battery.
Is that 13.96V at the Peltier terminals?...........................
I tried supplying it with a 12V @ 12A PSU.. i still get a 2A draw at 13.96V..
Yes sir.Is that 13.96V at the Peltier terminals?
A 60W Peltier Tile (TEC-12706) sir.You have a 4 ampere hour battery. You should have charged it at 400 milliamperes constant cutrent for 10 hours Prior to testing it under the load.
At the battery university it recommeds a charging voltage of 2.25 volts to 2.30 volts per cell.
Speaking of loads, what is the load the requires this battery?
You are getting that voltage when the battery is loaded with the Peltier load?Yes sir.
Thank you sir.. I will consider trying another battery.If the voltage drops rapidly when you connect the load, the battery is dead. I would suspect the voltage would drop from 12.6 to closer to 11 and then drop slowly as you deplete the battery. Remember, your not going to run that Peltier for more than 45 minutes, and if the battery is weaker, that time will be decreased.
If you want a longer use you'll need to have a battery capable of more than 48 watts/hr.
Yes, I got the voltage when the peltier is connected.. but most of the time, I get less than 12V (10~11V)..Is that 13.96V at the Peltier terminals?
That sounds like the open circuit voltage.
OCV=Disconnect any loads from the battery. Use your Multimeter in DC Volts (20V or Auto-ranging) mode, put red lead on battery +, black lead on battery -, and read the voltage. If it reads less than 12.60V, the battery needs charging or needs replacing.Yes, I got the voltage when the peltier is connected.. but most of the time, I get less than 12V (10~11V)..
I'm not familiar about the open circuit voltage.. what do i do about it? Thank you.
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Aaron Carman
