Im trying to make a high current power supply to test car stereo equipment. It's based on http://hmin.tripod.com/als/andysm/drawings/supplies/10A-PS10.GIF
and http://www.reuk.co.uk/OtherImages/high-current-voltage-regulator.gif
Also attached is an lt spice model of the circuit. Will this work okay or will the resistor values need to be different. Will this circuit handle near the 70 amps the bridge rectifier can. p.s. after the two 8200uf caps the output voltage is approximately 20.6v. thanks for any help.
