High Current PCB Traces?
Discussion in 'General Electronics Chat' started by sailmike, Jan 21, 2015.
  1. sailmike
    Nov 11, 2013
    143
    I need to make some changes to some of my circuit board designs to handle higher current of about 1A at about 3V. I am just wondering what's the best way to go about this? Just increase the trace width? Or increase the copper thickness? Or a combination of both? Also, what are typical thicknesses? What issues are there with each method?
    Thanks,
    Mike
  2. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi.
    Look at page #7 of this tutorial.
    E
  3. nigelwright7557
    May 10, 2008
    488
    71
    Have a look on google for track width calculators.
    You can input copper ounces and current required and they will give you minimum required track width.
  4. sailmike
    Nov 11, 2013
    143
    Ericgibbs, that's a good tutorial. Thanks! Do you happen to know of one like that for 4 or more layer boards?
  5. ericgibbs
    Jan 29, 2010
    2,575
    389
    hi,
    This is a link to a vid for Altium multilayer design, also the link has nested links for pcb design.
    E
  6. mcgyvr
    Oct 15, 2009
    4,783
    973
    increasing trace width is the best way assuming you have the room to do so. thicker copper = more money.. thicker trace does not
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    a cheaper way is to solder wire on the traces that need it. if a design is already done. and specifying thicker traces for a layer on a 4 layer board could be very expensive too. for a little more current carrying, tin the traces.
  8. mcgyvr
    Oct 15, 2009
    4,783
    973
    Most of the calculators have an option for "internal" or "external" traces.. that will account for your multi-layers..
  9. kubeek
    Sep 20, 2005
    4,686
    805
    Also with thicker copper you might have problems with fine pitch pads and traces.
    ErnieM likes this.
