I am testing some theories for the production of carbon nano tubes using the Arc discharge method. Long story short, I need an AC supply of about 100 amps and approximately 20 Volts to vaporize the graphite electrodes.
I look at this and immediately think transformer. I can use one to step down the voltage and in turn raise the current. I am familiar with the formula. Assuming I have a fairly accurate 120Volts AC from the wall with 20 Amps, I would need a turns ratio of 5:1 to produce 100 Amps at 24 volts. I also know that I should put a 20 Amp fuse at the plug.
However I understand the extreme safety risks that are involved with high current and I recognize that this is a lot more than enough current to be fatal. That is why I want the thoughts, opinions and recommendations of you guys before I end up blowing myself up. Or am I looking at it completely wrong?
Thanks in advance
Thanks in advance
