high amps mosfet transistor
Discussion in 'The Projects Forum' started by mah, Apr 30, 2015.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    why pwm the supply to the solenoid?
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    According to the other thread it is a proportional valve?
    Max.
  4. mah
    Mar 15, 2010
    276
    yes , it is a proportional valve
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Well the Mosfet is low RDS on and rated at 50amp and logic level input.
    What is the voltage of the valve?
    Max.
  6. mah
    Mar 15, 2010
    276
    24 volt
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    Appears the heat sink would need to dissipate <1watt.
    Max.
  8. mah
    Mar 15, 2010
    276
    will it work?
